Need help saving my water damaged Samsung S6 Edge
A
AC Question
My S6 Edge was dropped in a puddle, only the bottom half sunk below the water. I grabbed it in literally 5 seconds and dried it off. I thought this phone was fairly water resistant so I didn't really worry. It worked fine for one hour before the screen refused to turn on. After about 30 seconds of trying to turn the display on it gave a bit of life and the screen powered up, after that scare I put it straight in a bowl of rice. The interesting thing is that the phone vibrates when I pick it up, because I have the smart pick-up setting on. However the display gave nothing. The phone has not been plugged in to avoid a power surge. Is there anything I can do to improve the chance of this phone surviving?
