Samsung S6 audio makes stuttering noise
I have a less than 1 y/o Samsung S6... Still in warranty. No water damage.
Sometimes (25% of the time) when I play audio from Twitter, Youtube, Netflix etc. the audio will start stuttering. It sounds like someone is putting their finger on the speaker, taking it away quickly and repeating.
If I turn the volume up or down, the problem still persists. I have to keep letting the audio go and after ~30 secs it goes back to normal. If I pause what I'm playing and then press play again, the audio is normal for only a few seconds.
Any solutions? Samsung told me to wipe cache partition...did that, no success.
Has this happened to anyone?
If I can't figure it out, I'll have to get it fixed. Thanks in advance!
