Battery problems drains fast and at 1% I plug in then it changes to 7% more info description.
A
AC Question
Battery problems drains fast and at 1% I plug in then it changes to 7% then wanted to drain the battery completely by turning off the fast charging mode on note 5 and it turned off. After that It is not charging or responding. What should I do?
tivativa
