A
AC Question
I went into the battery usage details and looked at how much battery the screen was using; 48% or 224 mAH. At this point I had 75% battery, so I took half of the 25% that was used, which is 12.5%. If 12.5% of total battery capacity is 224 mAH, then the total battery capacity is 1792mAH?!?!?! That makes no sense at all, since my LG V10 has a 3000mAH cell, and even if there were errors it should not have been off by 40%.
Is there a reason for this, or do I need to recalibrate my battery or something?
