Charger not working properly
aparnapr121
4
Hi
I have a Samsung Galaxy S3..just 1 month before it was getting charged properly..But now its taking almost an hour to charge to 1 %. But then I tried charging using my computer with the usb cable.....Then its charging perfectly, Its also charging perfectly when I tried charging my phone with Nokia Lumia and Xperia J chargers.....Can some body please help me on this issue:-\
After this incident I went to the Samsung service centre .They told me that its the problem with my adapter and got my adapter and usb cable replaced . And so my phone was charging properly with the new charger almost for 3 moinths. Now again the problem happened.Although I have plugged it into charging for almost one day,my phone was not at all charging even for 1 percentage. Then finally I connected my phone to my laptop using USB cable and now it started charging. I am very confused about what could be the reason ?Is there any problem with the phone that,this issue is occuring again and again Please suggest a solution
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
I'm not following the problem. When does it charge properly and when does it cause problems? As for warranty, if it's under a year since purchase them it should be covered. Most carriers might just give you a new charger if you ask politely :).
Sent from my SPH-D710 using Tapatalk 2
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
I am inclined to agree with magnus. Ask for a charger first. If you are still having issues..it is the device USB port.
Sent from a Slim 4.3 S3
aparnapr121
4
Post edited. Please have a look at it. The phone doesnt charge when I charge it using the adapter and plug it into the socket. But when I connect my phone to the laptop,it is chargin slowly.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Might see like a dumb idea, but maybe a different wall socket?
aparnapr121
4
I have tried that also. Its not at all charging. I wonder what might be the reason. because its charging in a quite okay manner when connected with my PC. Its been only 7 months i bought my phone n this is my 2nd charger:'(
