Hello!
A little while ago, while my Google G2 was updating the battery died, interrupting the process.
When I went to turn it on later, after having charged it, it would load the HTC screen and stay frozen there, unresponsive to button commands.
I pulled the battery out, went to the HBoot screen and tried to Factory Reset, but it would freeze.
Recently, I went to look for some ways to fix my phone and learned that you can update the system from the SD card. I found that I was able to access the recovery menu, so I downloaded an update package, put it onto my SD card labeling it as "update.zip" and I tried to apply the update, but it didn't work.
When I go the recovery screen and run the update I get these errors:
E: Can't mount /data/data/recovery/log
E: Can't open /data/data/recover/log
E:set_bootloader_message_block: emmc_read_data fail!
-- Install /sdcard ...
Finding update package...
Opening update package...
Verifying update package...
E:signature verification failed
Installation aborted.
E: Can't mount /data/data/recovery/HTCFOTA/update_result.log
E: Can't mount /data/data/recovery/OMADM/update_result.log
I'm a bit out of my depth when it comes to fixing the phone, especially if it involves fixing the eMMC. Is there any way around this problem? Am I loading the update from SD card incorrectly?
Any help would be greatly appreciated.
