I was curious! If ICS devices have no physical buttons on the front ie: Home, Back, Menu/ Settings, Search. How would the current HC devices fare with a ICS update? If you already had the physical or capacitive buttons on a Honeycomb device how would a Ice Cream Sandwich update, look or feel on a device that has buttons already on it?
I was thinking is it worth buying a new HC device now, or waiting for a ICS device in the near future, will the ICS update be that big of an update, hardware wise? :-\
