Results 1 to 2 of 2
    Default Wifi - very long delays acquiring IP address
    I have an Evo 3D, stock, that's having problems connecting to my Cisco WAP610N. For some reason, it takes about 15 minutes or so-- the time varies. It seems to get stuck at acquiring an IP address. No other wifi enabled devices have the problem, and I have no problem connecting this to other access points. It's a little strange to diagnose. Anyone heard of such a problem? Any suggestions on how to troubleshoot it? Thanks.
  2. #2
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Default Re: Wifi - very long delays acquiring IP address
    Well, for starters, when people have some issues connecting to their router, usually changing the channel on the router helps. Android gets a little picky with router channels sometimes.
