I want to buy a used phone for around $50 on eBay,I'm looking for something with a good camera that will work in London and Dublin
Sent from my EVO LTE using Tapatalk 2
You'll need a World phone that is capable of GSM connectivity sine I don't think any European networks work on Sprints cdma.
Good luck with your search.
Sent from my SPH-D710 using Tapatalk 2
Doesn't the sprint s4 have a removable sim? Or is that only the Verizon model?
Sprint GS3 Running TN's Msg and Chubbs
Have you looked into the Photon?
