Samsung Galaxy S3 System recovery Problem (Android laying on his back) HELPPPPPPP!!!!
sirbentley
Hey, you guys and Gals. I have a serious problem that I have been trying to figure out for some time now. On my Galaxy S3, when I boot into recovery mode (Do so by Holding down the Vol +, Home Button, and Pwr Botton), I see a android figure laying on his back. He has a red box with an exclamation point in it. Here is a pic of it:
Within this boot process, it use to let me recover, and many other options. now it only reads in royal blue as follows:
reboot system now
apply update from ADB
Apply update from external storage
wipe data/ factory reset
wipe cache partition
apply update from cache
And up under the fallen android figure, it reads in yellow as follows:
# Manual Mode #
-- Applying Multi- CSC...
Applied the CSC-code : ATT
Successfully Applied multi-CSC.
Can anyone help me with this problem? If so please leave a comment for the key to fixing this issue. Thanks!!!
hey man i have the same problem but don't know how to fix it. i just have a question did you try ti wipedata/factory reset ?
careerzoneacademy
