Why do some AC members show: "post;" "global post;" & whether "stock" or not
jdbii
660
Anybody care to explain why some member's avatar displays just "post," and other's display much more detailed info. Thanks.
i.e. What does "Global Post" refer to, and where do you input your info to show whether you have stock or something else?
Jennifer Stough
Retired Moderator
Feb 12, 2013
1,971
7
Re: Why do some AC members show: "post;" "global post;" & whether "stock" or not
I am unsure of the option to show stock or not, but global posts refer to posts on other mobile nations sites.
Jennifer Stough
Forums Moderator
Droid DNA
jdbii
660
Jennifer Stough
Forums Moderator
Droid DNA
Thanks. That makes sense.
anon(394005)
Banned
Jul 5, 2011
1,914
162
To get to the area to enter your ROM info (ex. stock), click "Settings" under your username in the upper left of the webpage, then select "General settings". It's at the bottom called "ROM/Kernel". :)
Edit: wait that didn't do anything (at least for me it didn't). You can probably put something in the "Mini Bio" section under "Settings, Edit Profile". it will then show up when someone clicks on your avatar.
jdbii
660
Sweet. Thank you. All of a sudden I find myself a bit thirsty. :)
