we have a phone that is not declining calls correctly while it is locked. It is a Motorola phone, i think it is a droid. When it receives a call, it rings and you have to drag the little ring up to either answer or decline the call. Even when it is dragged to decline, it will answer.
the same does not happen when it is unlocked, because then it is given answer and decline buttons and he can just hit decline and it works.
