HELP - S4 and Android App Crashing (Tides and Current)
TraderX
7
Ok, I have a Galaxy S4,and I heard Tides & Currents is a great android app from users of the Galaxy S3.
So I downloading and installed on my S4, but it crashes when I try to run it... every time. I have uninstalled and re-installed it about 20x, but still not able to get it to work.
Has any one else experienced the same issue on a S4? Any solution to correct this? Support doesn't seem to reply to any questions.
What would be a great alternative (app) with close to the same functions and experience?
Any help would be great, as I'm pretty frustrated.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Have you emailed the developer about the issue? I know you said support isn't helpful but who are you contacting?
TraderX
7
I've sent email directly from their web site.
Question: As this app is downloaded from Amazon, and not Google Play, could this be a possible issue?
Any suggests would be most helpful.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Maybe. Play automatically filters apps that are compatible with your device.
From a Sprint Moto X using the AC forums app.
TraderX
7
Any other possible solutions?
I've had a few more friends with droid (non S4) install this app... but yet I am not able to.
What am I doing wrong?!?!?!?!
RandyRoyalty
