Is it possible to update the Android software on a Wacom Cintiq Companion Hybrid?
jessemkv
I'm thinking of getting one and I'm wondering if you are stuck with Android 4.2
I can't find an answer anywhere so I thought maybe somebody here might have one.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums.
I think I found their website, and I would guess that since there is no download area for newer versions of Android, I would guess no; it can't be updated. However, if there was a version to be stuck with 4.2 isn't bad.
Je Bu
I do have the Cintiq Companion Hybrid 32gb - wonderful device!
There is an wacom software on the tablet which allows you to update when updates available ...I had already one since I own it.
Since those updates include very specific adjusted driver to give you all the wacom pen and screen features ...the updates will not be as regularly as normal android updates ...
