Is there a compatibility issue with 10.4 OS X?
When I plug my Moment into my iMac it does not connect, it does charge though.
I am aware of the drop down menu with the option to connect, as I can connect it to my work laptop (Windows XP) with no problems, it just does not pop up with the Mac.
(I need to try my son's, as he is running an Intel based one)
