Which micro sd card to get?
Oct 31, 2012
24
just a general question,i need to get a micro sd card for my xperia z2 tablet,im not sure of which class to get,or size of them,although im pretty sure 32 or 64 would suffice.i may download several movies for the kids,all help appreciated,
cheers john
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Re: which micro sd card
Most devices should be able to support up to 64 GB. Not sure about the newer 128 GB microSD cards, though. Most microSD cards I see are class 10, which is good. Stick with well-known brands like Sandisk, Samsung, Toshiba, Patriot, PNY, or Transcend, to name a few. And be careful about ordering them from eBay or from some marketplace seller on Amazon--you're more likely to run into a counterfeit card.
When you have the card, you can run SD Insight on your device to make sure the card is what it says it is.
