Annoying message comes up after downloading
Just yesterday, I downloaded a Battery fix app, and since then, I've been getting this popup message saying," <file> is ready" and below it, "try <app name>". I uninstalled the supposedly offending app, ran different Adware remover apps, ran couple antivirus and cleaners. I even did a factory reset. It's still there. Is there something I need to disable? I've attached a screen print.
Thanks!
Rich
- 1) Galaxy S4 running on kitkat 4.4.4
- 2) am not rooted
- 3) Suspected App downloaded: Battery Life Repair or Advanced Battery
Thanks!
Rich
