How do I reinstall OS after wiping my Nexus 4?
gomakeitreal
3
how to reinstall OS after wiping my nexus 4
actually it is more complicated than that.
i first flashed it to TWRP (no problem).
after sometime i want to flash it 5.0.1 lollipop.
i used nexus root toolkit 1.99. the flash seemed to failed.
it is still 4.4.4, but all 3 virtual key at the bottom does not work anymore.
then i tried to factory reset. no go. then my stupidity kicked in. i booted into twrp and wiped the phone.
now when i boot up the phone, it is stuck in the google logo, and nothing came up anymore.
help is very appreciated!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: how to reinstall OS after wiping my nexus 4
Find a zip file for a ROM for the phone. Go into TWRP. Install that file. It can be stock 4.4.4 or stock 5.0.1 (or anything else that will install, including a custom ROM - just get the phone working, then you can worry about finding an installable or updateable 5.0.1).
gomakeitreal
3
thanks.
that worked.
but the other problem remain. my 3 virtual keys are not working anymore. (home, back, and the other button).
(actually when i went into TWRP, its home and back button did not work either)
any idea?
thanks a lot!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It probably is hardware-related. I don't think I've ever used the Home button in TWRP, and the menu button would be useless, but I usually use the back button, not the on-screen back arrow and keep wondering why every time I do).
tress
