Re: "obtaining Wifi" prob.... no solution working :-(
Get into setup on the router and try this:
On dual band routers give the 5GHz and 2.4 GHz bands different SSID names. When setting up the 5GHz band usually it's best to set the router to use a channel well over 100. Over 150 is best.
Set security encryption to WPA2/AES. Do not use WEP, WPA2/TKIP or WPA2/AES/TKIP.
When done setting up the router, if you can't connect unplug the power for 30 seconds, plug it in, give it plenty of time to reboot, like 3-4 minutes and try connecting again.
If still no go, on the phone go to: Settings > WiFi > Menu > Advanced > WiFi frequency band > select 2.4 GHz or 5 GHz instead of Automatic. The phone may be struggling with choosing one, so choose one for it.
If still no joy, since you say you did get a connection but no data transfer, it's possible, though unlikely, that you have a DNS problem. I don't expect it to make a difference if other devices are not having problems. But if you wantto be sure there's a couple of simple tests you can run.
Ping test. If you don't have one, Install a terminal app:
https://forums.androidcentral.com/e...details?id=jackpal.androidterm&token=-U5tTXp-
Open a terminal and type: ping -c5 74.125.224.72
That will ping google.com 5 times, stop and give the result.
If you can successfully ping Google but not go there with a browser, try this:
Test if using an IP address rather than a website name allow you to connect. For example, instead of 'google.com' use '
http://74.125.224.72/'. If it works it's a DNS problem.
Try clearing your browser cache and cookies. If still no good you can try setting Google DNS servers. 8.8.8.8 for the primary and 8.8.4.4 for the secondary.
Android since v1.0. Linux user since 2001.
