A
AC Question
Music player loosing track of place.
I downloaded some podcasts that are over an hour long and if i get a call or pause it, the player will loose its place and then when I go to find its place by sliding the bar it still wont find the correct place.
any ideas? I have also downloaded a couple other apps and same thing
