Why are is the sound on notification panel and pictures darker than usual?
A
AC Question
Sound on notification panel and Pictures darker than usual
Just wondering if you can have sound on the notification panel similar to the brightness bar. Also, when I use the camera app the pictures are always much darker than what they appear to be.
Thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Re: Sound on notification panel and Pictures darker than usual
Welcome to Android Central! Which device?
