Re: Ads appearing at the bottom of the screen
Okay, after a some tests i found the answer.
It has nothing to do with ad ware or anything, it's not a virus either, that thing only appears when i have some specific " go launcher " themes installed, i installed them on bluestacks just to do the test and whenever i uninstall them that thing disappears.
Anyway, thank you for your efforts.
