It finds my printer but won't print, what should I do?
A
AC Question
Printer was working fine and all at once it just wouldn't print
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Re: It finds my printer but won't print
What device are you using to print from, and what printer do you have?
Sent from my Verizon LG G4
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
I use Cloud Print and that happens once in a while. I just delete the printer, then add it again. (If your printer is on wifi, and you reset your router, or connect a device while the printer is off, the printer's IP address will change, and nothing on the network, including cloud printing, will work.)
RandyRoyalty
