Why can't I run Hot Spot and 3g at same time?
A
AC Question
So,my phone has a data plan with its own wifi,and I have a mobile hotspot.I want to use my phone while my daughter uses the hot spot,but when she's connected,my phone won't work.Why?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Welcome to Android Central! It should still work. Which phone do you have? Are you using the mobile hotspot that came with the phone, or a 3rd party hotspot app?
