GPS questions related to an Android Device
I realize this may vary slightly depending on which android device you are using, but
generally, when an App on your device asks your device for a GPS where does your device go to get the GPS?
Does it default to hardware inside the device?
Does it go to the device’s service provider?
Could it be provided by another App also on the device?
