Hi Everybody, I have just purchased today a wired selfie stick and not sure if its compatible with my LG Nexus4 5.1.1.
What do I need to do to make it compatible.
Thank You.
Thank You.
Did the selfie stick give you a list of compatible devices? Space I would suggest taking a look at that to see if there are any minimum requirements and if certain device models are supported or are not supported.Hi Everybody, I have just purchased today a wired selfie stick and not sure if its compatible with my LG Nexus4 5.1.1.
Thank You.
