My Bush 5" Android won't connect to my PC and I have no idea why. I am wanting to root it so I can do more but have no idea if I can or not due to it not being recognised by my PC! Any help is appreciated!
Welcome to Android Central! Have you tried a different USB cable? Some cables are for charging only, and have no data transfer wires.
Also, when you connect via USB, swipe down the notification panel--is there a USB notification there? If so, tap it and make sure MTP is selected. You might also need to make sure USB Debugging is turned on in the Developer Options (to turn those on, go to Settings>About Tablet and tap Build Version 7 times).
