Does the built in web browser support APK installation?
Hugh Johnson
92
11
I'd like to know if I can access an url directed to an .apk file on my Android device through the built-in browser and have it launch the install screen when downloaded.
Seems like it would be much easier to do than put it on an SD card and use a file explorer to install an app,
Moscow Desire
Troubleshooter
Mar 3, 2011
1,801
135
Seems a backwards way to do it.
Most, use the barcode reader app.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
You will need to download the .apk and access it from the sd card. Use a file explorer to find it, select it, and install it. Make sure the box is checked in application settings to allow non-market installation.
Hugh Johnson
92
11
Thanks for the info guys. :)
Do'h! That never crossed my mind but I can see that being a lot easier on long urls, so pretty much anything typed in through the tiny little keyboard. lol
I actually have an extension installed in Firefox called Mobile Barcoder that creates a QR code for pages the page you're on when you hover over its icon in the task bar. I've only needed it once so far but it sure helped!
tress
