Results 1 to 14 of 14
- 12-27-2012, 11:55 AM
Thread Author #1
Nexus 4 Shutter Sound
I read somewhere that there is a new API in Android 4.2 that allows the shutter sound in the camera to be changed. Has anyone confirmed this? Shutter sound is trivial I suppose, but if you take a lot of pictures you want your phone camera shutter to at least sound like a real one, not this "ping" noise I've hated in since 4.0 (Got better in 4.2, but still). I'd like to swap out the camera shutter sound with that of the GS3 as I feel it sounds more authentic I suppose. Don't know if thats possible yet.
EDIT: From the Android Developer section:
Improved Camera with HDR
Android 4.2 introduces a new camera hardware interface and pipeline for improved performance. On supported devices, apps can use a new HDR camera scene mode to capture an image using high dynamic range imaging techniques.
Additionally, the framework now provides an API to let apps check whether the camera shutter sound can be disabled. Apps can then let the user disable the sound or choose an alternative sound in place of the standard shutter sound, which is recommended.
So, are there apps to allow the change? - 12-27-2012, 01:45 PM #2
- 12-27-2012, 01:49 PM #3
- 12-27-2012, 02:33 PM
Thread Author #4
Re: Nexus 4 Shutter Sound
So all I would have to do is delete that camera_click.ogg file, find a file of the SGS3 shutter sound in .ogg format, and just download it and put it in this "UI" folder?
What do you mean "root name"? So if I wanted the GS3 shutter sound, it would have to be renamed to "camera_click" or what? - 12-27-2012, 02:56 PM #5
I haven't tested, but yes, it seems that way. If you "play" the existing camera_click.ogg file, it is most definitely the default shutter sound.
Yes, I would expect that your sound file will have to be named "camera_click" (until such time as you can find a suitable sounds manager app). It may or may not need to be an ogg format file.What do you mean "root name"? So if I wanted the GS3 shutter sound, it would have to be renamed to "camera_click" or what?
If you want to play, 1) make a copy of camera_click.ogg in a safe place. 2) make a copy of one of the other sound files in the same folder but name it camera_click.ogg. 3) take a picture and see if the new sound is now your shutter click. 4) Assuming that works, maybe try the same thing with a short mp3 file (named camera_click.mp3, of course) and see if that works. - 12-27-2012, 03:19 PM
Thread Author #6
- 12-27-2012, 03:24 PM #7
- 12-27-2012, 03:37 PM
Thread Author #8
Yup, seems like I have to be rooted. I tried, for example, moving the Facebook notification sound to the SYSTEM-MEDIA-AUDIO-UI folder, and it said "Could not write file" or something. Renamed it to camera_click, still wouldn't work. Therefore, i'm assuming if I can't put any sound in to that folder, I wouldnt be able to add a new shutter sound to it. I may be wrong though but it seems like root is necessary. Thanks for the help though.
- 12-27-2012, 04:18 PM #9
- 12-27-2012, 04:27 PM
Thread Author #10
- 12-28-2012, 07:49 PM #11
If you put the ringer volume down doesn't the camera sound mute?
Sent from my Nexus 4 using Android Central Forums - 12-28-2012, 08:35 PM #12
I just changed the camera click sound. While I was in there also changed the low battery sound. Works fine. Must be rooted.
Sent from my mako (
- 12-29-2012, 12:54 AM #13
- 12-29-2012, 06:34 AM #14
Is it possible to silence the shutter sound?
By kalex1114 in forum LG Optimus SReplies: 9Last Post: 02-05-2011, 09:41 PM -
Shutter Sound?
By Dirty Ders in forum Motorola Droid XReplies: 23Last Post: 11-07-2010, 12:31 PM -
Re-enable camera shutter sound
By dcreed in forum Motorola DroidReplies: 6Last Post: 10-13-2010, 01:29 PM -
Turning off shutter sound on Droid
By mugenprincess in forum General Help and How ToReplies: 10Last Post: 08-31-2010, 02:26 AM -
shutter sound
By Shafe75 in forum Verizon Droid IncredibleReplies: 2Last Post: 05-01-2010, 12:00 AM
Reply
