Finally got a Nexus 5, and am trying to figure out how to move all my SMS/MMS over. GNex uses "Messaging", while N5 uses Hangouts.
Any help would be appreciated.
Thanks!
Gayle
Thanks!
Gayle
MyBackup Pro will or you can try this one: SMS Backup & Restore.
Note, I am not sure if SMS Backup+ will restore to Kit Kat devices....
Thanks! To be 100% clear, you are saying MyBackup Pro and SMS Backup & Restore will work with a non-rooted phone?
Let us know how it goes.
Success! I have successfully moved my SMS, MMS, phone log, and photos over using MyBackup Pro. What I don't seem to be able to do (or haven't figured out) is move app-specific data (e.g. my notes in ColorNote). Do you have suggestions on how to do that?
For that, since you are not rooted, the only solution I know of is an app called Helium. I have moved app data between phones successfully (both phones are not rooted).
For future reference, Helium can also backup / restore SMS messages (not sure about MMS and call logs).
OK. I somehow got the driver installed and got the backup file transferred from PC to phone (also got music transferred from PC to phone). When I run Helium and try to restore from backup, now getting error: "No backups were found on your Internal Storage. Maybe you should make some."
Anyone know how to deal with this?
How did you make the back up? On your old phone, did you start Helium and select PC Download from the overflow menu? If you do that, use your PC to go to the website displayed on your phone. That will download the backup to your computer. Then do the same to restore on the new phone.
No, that's not what I did at all. Per a YouTube video I watched, I backed up to the device, then copied that folder to my PC, then copied that folder to the new phone. I'll try doing what you've suggested, thanks again! I'm making progress, albeit not as quickly as I'd hoped.
