Found out how to fix this issue.
Go to the Settings, then select Battery.
Click on the top left hand corner, where the 3 dots are, and select Battery optimization.
Tap "Not optimized", and select All Apps.
You will see all the apps are now selected for Optimizing battery use.
This next step is the most important: hit your home button now.
Leave that setting page running in the background!
If you hit return, or go back, it will reset to not optmizing!
Now you will see your batter last, guaranteed.
The only catch is having to leave your settings page running in the background, on batter optimization.
If you need to use your settings page to do anything else, that is fine, but always go back and turn the Battery optimization back on and leave it on!
This has worked great for me, battery lasts a long time. With great use too.
Good luck.
