A
AC Question
Fiio E18 portable d/a micro USB audio converter with Nexus 6
Now I have bought it. I see (after looking all over) they only have Nexus 5 listed as supported (not 6) . I have tried messing around with the developer USB options but so far no luck. It just says NO USB audio device found.
Any suggestions apart from sending it back?
Would rooting it work?
Thanks in advance
Thanks in advance
