I am hoping someone can help me. I have having issues with my tablet as well as having other strange problems I did not have prior to the Lolipop 5.0.2 update.
I continue to get the following error message: Trying SDK – 21 –---- getPhone error – java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.String com.woodslink.android.wiredheadphoneroutingfix.phone.enumPhones.name()' on a null object reference
It pops up multiple times a day. It started happening after the Lolipop 5.0.2 update. The table is not rooted and completely stock.
Additionally and I am assuming this is related, z7-android-log files are being generated frequently. 100 plus new files are created every few days which I have to manually delete.
A few more things worth mentioning that may be relevant. Not sure if any of these things are in fact related but they have all started since the update.
I have noticed that the program Outlook.com has not been working properly. The connection to the server continually times out and the only way for me to connect is by restarting the tablet. Is this the reason for the z7 log files?
Another issues is Pandora. It crashes constantly. The only way to get it to work is to restart the tablet.
Also just to let you know I use a program called SoundAbout to prevent the speaker from working despite headphones being plugged into the tablet. I have had this problem since I have owned the tablet.
Thank you in advance for any assistance solving this issue. It is most annoying and I don't have a clue to how to resolve the issue. Please let me know if I need to provide additional information.
