*** TAMPERED ***
*** UNLOCKED ***
JEWEL PVT SHIP S-ON RL
HBOOT-1.19.0000
RADIO-1.12.11.0809
OpenDSP-v29.1.0.45.0622
eMCC-boot
Aug 9 2012,15:14:25
HBOOT
Backed up and then flashed CM 10 last night to try it out. I was just running the stock ROM, unlocked, originally. I had trouble getting CM 10 to take, so I read up and learned about dumlock. That did the trick. After playing around CM 10 for a while, I decided I liked my original ROM better, so I tried to recover it. Going back caused a boot loop.
So now, I can get into the bootloader, which is a good thing. I had an issue with the sd card and internal memory not being able to be read, so I formatted both, which fixed that problem. Reloading CM works, but the USB won't communicate with my computer. Also, wireless and mobile antennas don't seem to work. So it's a real mess.
Does anyone have any suggestions on how to fix this, please?
Thank you in advance.
*** UNLOCKED ***
HBOOT-1.19.0000
RADIO-1.12.11.0809
eMCC-boot
Aug 9 2012,15:14:25
HBOOT
