Battery after JB
Jaggrey
796
20
18
For what it's worth, I have left it enabled, but have disabled Location History within Google Maps (which Now uses for some of its functionality, but which isn't required) and it seems to have made a huge difference in battery conservation. Please try this and let us know if it also seems to work for you. It'd be great to find a way to keep Now enabled for those who want it but still not completely sacrifice all battery life.
I've also seen a difference after doing the same thing. It's a bit early to tell but I compared one hour to the next and saw much less battery drain.
Sent from my Touchpad using Android Central Forums
Andras
289
6
Do you lose the travel time home cards by doing this?
vbockius
199
My location settings in Maps app....did get travel time card last night when I was leaving for work....and that's my battery after being off charger 8 hours and 41 minutes
odror
Active member
Dec 21, 2010
37
I have had 20-30% increase in battery usage for example, playing podcast uses more battery than it did before. The phone is on power saving mode. It reminds me the poor battery life of the first evo.
Cherenkov
206
4
So far my battery's been somewhat similar as before. I'm losing about 10% more per day than before, which isn't terrible and still leaves me at around 60% at the end of the day. Something I noticed today, the OS upgrade turned NFC back on. I usually keep this off by default. Check if yours is on. If you don't use NFC, it might help your batter life a bit.
NastyNeil
728
4
I just enabled Google Now, and am now going to select only a few cards that I want on(weather, sports, emergency alerts) and I turned off Location History. I want to see how much of a difference it makes for me. On a side note, what do most of you have set for your GPS settings. I have Google's Location Service, Location & Google Search, and Compass Warning all checked and GPS satelites unchecked.
John Matuszek
Active member
Nov 16, 2012
32
I don't think I'm doing too bad a couple of days into the update
And no I haven't hit the charger once during this
Sent from my EVO using Tapatalk 2
John Matuszek
Active member
Nov 16, 2012
32
I would love to see what your settings are and what your normal daily usage is.
Today was a light day and 8 hours of that was with the phone idle while I was sleeping. All my settings are normal except I turned off the connection optimizer. I also spent a lot of time on wifi today
dwb3838
180
3
Since the jellybean update my battery life is horrible and I have the same use as always . Have tried everything but nothing seems to help .
axllebeer
Trusted Member
Aug 8, 2012
323
I had an app using over 35% of my battery at I hadn't even used since the update.
It was Poynt. I deleted it and downloaded it again and it seems to be behaving itself now. Worked for that app so might work for others. Unless its something native like the camera app of course. Good luck deleting that lol
John Matuszek
Active member
Nov 16, 2012
32
Putting in on the charger for the night got a long day in the morning and need a full charge. So here is my final battery shot at 7%
Love Divine
500
36
Same here!
Battery life noticeably declined after the update. I looked at my usage at the end of the day, and Poynt's usage was 57%, despite the fact that I hadn't used it in months. Uninstalled, will see how that affects things.
BoredandTattooed
196
If you guys are having battery issue since JB, sorry to hear, I still get all day long..
mehammed
