BigDroid
Active member
Quick question:
I had MIUI since yesterday and I have been
playing with it for awhile... Recently, when I try
to connect my evo to my mac, the pop-up window
in where you select on what connections you want to
use (charge or mount SD) is gone
I tried wiping, and fixing permissions.... no fix....
I tried reinstalling the rom (I'm on 1.3.5-EN) yet.... no luck ;(
I really like this rom so far so anyone know how to fix this problem?
Thats one of the flaws with the MIUI rom.You have to boot into recovey while your phone is still plugged in to the computer and go to mounts and storage and hit mount usb storage nce you do that you can copy files to your card.
