I have a weird problem happening with my Hero. Whenever im working and have the Hero in my pocket i go through 2 batteries but when I am off work and at home and even playing around with my phone i can go the whole day on one battery charge. The only thing that I can guess can be causing this is that where I work there a lot of dead or weak signal spots so it is possible that while the phone is in my pocket that its searching for a signal and this is causing my battery to drain quickly? If so is there a setting that I can disable, perhaps roaming???
thanks
Angelo
thanks
Angelo
