Low battery notification sound - HOX
hockpuck
I'm not finding a sound notification within the settings of the phone when the battery is low. Am I overlooking it or do I need to get an app for that?
If I need an app, can anyone suggest a good one? I've looked at some but there's no mention about sound notification when the battery is low.
Thanks
MONDINGO
516
Thanks
Mine pops up on the screen when getting low. Makes a beep sound. And the led notification light blinks red. Maybe your not letting the battery get low enough.
Sent from my HTC One X using Android Central Forums
hockpuck
Thanks. I was in and out of the room. I came back and it was off. I tried to boot but it had the flashing red light. I charged it and all was fine. I was wondering if you could maybe set the alert to go off at maybe 20% battery life left, so I could charge it before it went completely dead? But I can't find how to do that on the phone. That's why I thought of maybe using an app? But I can't find one that says it can do that.
MONDINGO
516
I'll have to look further into that. But would be good.
MONDINGO
516
You can try downloading a secondary battery app. It'll tell you how much better life you have in increments of 1%. Rather than just the battery indicator on the top of the notification bar.
MangoPowah
1,585
Mine has a sound go off at 15 and 9%.
robthesixthree
119
3
Yup battery widget allows you to set it to your liking. Search the play store :thumbup:
kevinrshay1984
