thecycleoflife
Active member
It was probably in one of those popup tips that show up on your screen when you first used your phone.
When using knock on, you have to double tap directly in the center of the screen. If you tap too high or too low it doesn't work properly.
Sent from my LG-D801 using Tapatalk 2
Always had the 80% knock-on issue with my G2 but yesterday all of a sudden It no longer works at all. Tried restarting, turning the feature off and then back on again, and nothing. It just wont turn on via the knock knock feature anymore. It WILL however knock OFF just fine. It is only the knock ON that is affected. This is driving me INSANE!
At the same time I also started having difficulties manually dragging down my notifications bar. It comes down just a bit then snaps back up instead of following my finger down. Now I find the only way I can successfully manually drag my notifications bar down is by slowly and carefully dragging from directly in the center of the bar. Prior to this, I could drag quickly and sloppily from anywhere on the notification bar on the first try with no problem whatsoever. Now it usually takes me a few tries.
Anyone else experiencing screen issues like this, or have any ideas how to remedy it??? Thanks!
I'm also having issues with the knock on feature. Working only about 50% of the time.
I also have issue with a screen lock loop. If I try to knock-on the phone and it doesn't work, I'll try again and it doesn't work, so I push the power button. The lock screen shows up for about a second, then screen goes black. I push the power button on again and it shows for about a second and the screen goes black. Sometimes I need to do this 10-15 times or more before I can actually unlock the phone. VERY ANNOYING!! Especially when trying to pull out the phone quickly to take a picture before missing the shot. Is anyone else having this issue or should I exchange my phone?
Hi y'all
Check out this video:
LG G2 Knock On Sensor - YouTube
It shows the sensor which is responsible for the knock-on feature. I discovered mine was covered by the screen protector, using an x-acto knife to cut it away has resulted in DRAMATICALLY improved knock-on for me.
yes, the screen protector was clear. that seemed to impede the sensor enough to cause a problem bad enough for me to google it.
I figured out the problem, for some reason its can change the knock on tapping speed and pressure.
I have a large finger, before I can knock on and off with a quick 2 taps. Now I can only knock off but not on, for some reason my 9 months old son can knock on all the time when he play with the phone, so I tried to copy him, imagine you are trying to pet an ANTS but very slow 2 tap and very lightly, anywhere on the screen it work, look like he play with my phone and got the phone to register the way he tap to turn it on, its frustrating, I couldn't figure out how to set it back to normal.
