xocomaox
Did you get the hyperion then?
No, MPJ 6000mah. I am guessing it's the same one re-branded.
Do you mind linking to the battery you purchased? Does it fit with a standard back or does it also protrude? I had planned to get just a spare 3000 and a wall charger, but an extra 28% capacity might be all I need.
Basically the same price.Yeah I'm sure it is. Or the hyperion is rebranded, or they both are lol.
Anyway, hope it works well for you too. Was it cheaper?
Just purchased the best4power 4500 mah battery on ebay for around $20. Fits the standard size back case. Supposed to arrive middle of next week. I will check back and give my impressions.
Please do. While I love my 6000 there are times where I've switched back to the stock battery when I don't want the bulk when I'm on the go. So a 50% increase in the stock size would be great.
How did it go?That's what I am hoping for although honestly I am kind of skeptical. But as I said I will post my results after I get a chance to use the battery for a while.
