[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
Re: [How-to] Revert to LS670V9, after installing OTA LS670VC/VD,
I don't, but I'm sure someone has one.
There should be a V8 nandroid on the unroot thread.
Thanks for this info, I followed it to the letter I believe with the following results:
The updater showed 100% complete and I waited a further 15min or so for the phone to reboot and show the LG splash screen. But all I saw was a blank screen. I unplugged the phone and attempted to to reboot through the stock recovery. I had to guess the key strokes and I do manage to get the SPrint tweet on reboot and funny enough I do receive calls but I cannot answer as the screen is blank and inactive. I ran the LG mobile tool and it says its up to date. I also tried factory reset (Guessing the key strokes comparing to another optimus I have) and still the dark screen of death!
Any ideas where to now?
Thanks:-\
Thanks:-\
I wouldn't really call this dark screen of death.
What actually happened is your phone has the newer LCD hardware which LG switched to mid-production. The older ROMs like ZV8 and ZV9 do not have the drivers for the newer LCD hardware. Thus you will notice they will boot with ZV8/ZV9 and be functional (including the touch screen), except there will be no visual feedback.
This is actually covered in a RED warning at the top of the first post.
If your purpose was to get a stock ROM with hotspot working, the last ROM that would allow that and work with your LCD is ZVC. You can get the substitutions for that in the Reference section at the bottom of the first post.
To get by the current issue of not having screen output, I suggest either you use Android Screencast (link in the first post) or do some operations "blind"
Update yourself to the ZVD full restore:
http://forums.androidcentral.com/lg...sprint-zvd-froyo-downgrade-now-available.html
Reactions: farbeh
Thanks sfhub, Androids screencast was a godsend! I did run into some trouble starting the screencast and the info on this page cleared it for me :Control your Android phone with your PC, unofficially of course | TalkAndroid.com
Thanks again.
Farshad
gives me an error cannot connect to server please try again later.
anyone know whats up?
idid evrything good.after a 40 mins later its giveme error that conection fial between pc and cell phone.my cell phone is only lg logo before and now only blank screen
i complet up to 100% and than and the end its says contection problem between phone and pc.my phone is completly black screen.and nothing showing up and when i run this program its take almose 1 hour.and than complet up to 100%.any advise.
08:35:11 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
08:35:11 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
08:35:11 : Start Date : 2012-09-01 08:35:11
08:35:11 : -------- Buyer Test mode ---------
08:35:11 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
08:35:11 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
08:35:11 : *****CheckOS Start********
08:35:11 : Microsoft_Windows_XP_Professional_
08:35:11 : *****CheckPCSyncPrograms Start*****
08:35:12 : PCSyncPrograms Not Found
08:35:12 : SetEmerModeAT()
08:35:12 : _IsConnectedPhone Call
08:35:20 : _IsConnectedPhone(2)
08:35:20 : 0 - NotConnected.
08:35:20 : 1 - Normal connect success
08:35:20 : 2 - Emergency connect success
08:35:22 : Checking the connection with the cell phone...
08:35:22 : dwWaitResetTime(40000 ms)
08:35:23 : Phone Mode(2)
08:35:23 : *****GetPhoneType Start*****
08:35:31 : Phone Type : CDMA
08:35:31 : *****Start GetPreviousStep*****
08:35:31 : _GetPreviousStep(dwStep:0xffff)
08:35:31 : *****GetPhoneBinaryVersion Start*****
08:35:31 : CSE mode -> Version Replace
08:35:31 : *****Get ESN / IMEI / MEID Start*****
08:35:44 : *****GetPhoneNumber Start*****
08:35:47 : Phone Number : 00000000000
08:35:47 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 00000000000, Model :
08:35:50 : _GetAuthMark : wAuthMark(9366)
08:35:50 : Wait 3Sec
08:35:56 : _SetAuthMark Ok : wAuthMark(9366), PhoneMode(2)
08:35:56 : *****CheckPCSyncPrograms Start*****
08:35:56 : PCSyncPrograms Not Found
08:35:57 : CLGMobileHttp Class ?Ҹ????.
08:35:57 : CLGMobileHttp Class ?Ҹ?...
08:35:57 : ****************CheckAndDownload********************
08:35:57 : ******Extract Start ls670zv7.cab*****
08:35:57 : Model Dll Dir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
08:36:11 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV7_07.S7_07.P60670.wdb\n
08:36:11 : WDB(or DZ) FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV7_07.S7_07.P60670.wdb)
08:36:11 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_1_0.dll\n
08:36:11 : Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670_W_0_0_1_0.dll)
08:36:11 : Extracted C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\\LS670ZV7_07.S7_07.P60670.wdh\n
08:36:11 : NNNNN WDB FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV7_07.S7_07.P60670.wdb)
08:36:11 : NNNNN Model dll FullPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_1_0.dll)
08:36:11 : Extract End ls670zv7.cab
08:36:11 : *****WorkModelDLL Start*****
08:36:13 : strPhoneBinaryPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV7_07.S7_07.P60670.wdb)
08:36:13 : strModuleDir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
08:36:13 : strModelDLLPath(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670_W_0_0_1_0.dll)
08:36:13 : m_nPhoneMode(2)
08:36:13 : Phone mode 1 = Normal
08:36:13 : Phone mode 2 = Emergency
08:36:13 : Phone mode 4 = CSE
08:36:13 : _DetachDLL Call
08:36:14 : _DetachDLL Call End
08:36:14 : Call fn_StartUpgrade
08:36:14 : ### Start Upgrade - CDMA ###
08:36:14 : ********* CDMA Model.dll input Parameter *************
08:36:14 : MODEL_EVENT : 32769
08:36:14 : PhoneBinaryPath : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LS670ZV7_07.S7_07.P60670.wdb
08:36:14 : ModuleDir : C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\
08:36:14 : BootWaitTime : 49500
08:36:14 : UsbHighSpeed : FALSE
08:36:14 : PhoneMode : 2
08:36:14 : NewPhoneBinVersion : ls670zv7_20
08:36:14 : ClearSI : FALSE
08:36:14 : AuthMark : 9366
08:36:14 : ********* CDMA Model.dll input Parameter End*************
08:3608:37:03 : wParam : 7, lParam = 1
:15 : wParam : 20, lParam = 420
08:36:15 : MODEL DLL Event : (20, 420)
08:36:15 : Model Dll Msg Not Found(20, 420)
08:36:36 : wParam : 6, lParam = 0
08:36:36 : MODEL DLL Event : (6, 0)
08:36:36 : wParam : 7, lParam = 1
08:36:36 : MODEL DLL Event : (7, 1)
08:36:36 : wParam : 7, lParam = 0
08:39:24 : wParam : 7, lParam = 6
08:39:52 : wParam : 7, lParam = 7
its oes up to 100% and than give me this error.
I did everything suggested. The update gets stuck at 4
5 and fails (telling me to reconnect phone)
Here is my log pls help!
15:27:20 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
15:27:20 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
15:27:20 : Start Date : 2013-08-06 15:27:20
15:27:20 : -------- Buyer Test mode ---------
15:27:20 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
15:27:20 : RemoveDirectory1 Error(5):C:\ProgramData\LGMOBILEAX\Phone
15:27:20 : *****CheckOS Start********
15:27:20 : Microsoft_Windows_Vista Professional_
15:27:20 : *****CheckPCSyncPrograms Start*****
15:27:20 : PCSyncPrograms Not Found
15:27:20 : SetEmerModeAT()
15:27:20 : _IsConnectedPhone Call
15:27:20 : _IsConnectedPhone(0)
15:27:20 : 0 - NotConnected.
15:27:20 : 1 - Normal connect success
15:27:20 : 2 - Emergency connect success
15:27:27 : Verifying phone connection...
15:27:27 : dwWaitResetTime(40000 ms)
15:27:28 : _IsConnectedPhone Call
15:27:35 : _IsConnectedPhone(2)
15:27:35 : 0 - NotConnected.
15:27:35 : 1 - Normal connect success
15:27:35 : 2 - Emergency connect success
15:27:35 : Phone Mode(2)
15:27:35 : *****GetPhoneType Start*****
15:27:38 : Phone Type : CDMA
15:27:38 : *****Start GetPreviousStep*****
15:27:38 : _GetPreviousStep(dwStep:0x5)
15:27:38 : *****GetPhoneBinaryVersion Start*****
15:27:38 : CSE mode -> Version Replace
15:27:38 : *****Get ESN / IMEI / MEID Start*****
15:27:50 : *****GetPhoneNumber Start*****
15:27:52 : Phone Number : 00000000000
15:27:53 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 00000000000, Model :
15:27:55 : _GetAuthMark : wAuthMark(5774)
15:27:55 : Wait 3Sec
15:28:01 : _SetAuthMark Ok : wAuthMark(5774), PhoneMode(2)
15:28:01 : *****CheckPCSyncPrograms Start*****
15:28:01 : PCSyncPrograms Not Found
15:28:02 : CLGMobileHttp Class ?Ҹ????.
15:28:02 : CLGMobileHttp Class ?Ҹ?...
15:28:02 : ****************CheckAndDownload********************
15:28:02 : ******Extract Start LS670ZV9.cab*****
15:28:02 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb\n
15:28:12 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll\n
15:28:12 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll)
15:28:12 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdh\n
15:28:12 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:28:12 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:28:12 : Extract End LS670ZV9.cab
15:28:12 : *****WorkModelDLL Start*****
15:28:13 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:28:13 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
15:28:13 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:28:13 : m_nPhoneMode(2)
15:28:13 : Phone mode 1 = Normal
15:28:13 : Phone mode 2 = Emergency
15:28:13 : Phone mode 4 = CSE
15:28:13 : _DetachDLL Call
15:28:13 : _DetachDLL Call End
15:28:13 : Call fn_StartUpgrade
15:28:13 : ### Start Upgrade - CDMA ###
15:28:13 : ********* CDMA Model.dll input Parameter *************
15:28:13 : MODEL_EVENT : 32769
15:28:13 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
15:28:13 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
15:28:13 : BootWaitTime : 49500
15:28:13 : UsbHighSpeed : FALSE
15:28:13 : PhoneMode : 2
15:28:13 : NewPhoneBinVersion : LS670ZV9_20
15:28:13 : ClearSI : FALSE
15:28:13 : AuthMark : 5774
15:28:13 : ********* CDMA Model.dll input Parameter End*************
15:28:15 : wParam : 20, lParam = 570
15:28:15 : MODEL DLL Event : (20, 570)
15:28:15 : Model Dll Msg Not Found(20, 570)
15:28:37 : wParam : 100, lParam = 83
15:28:37 : MODEL DLL Event : (100, 83)
15:28:37 : CleanModelDll() : Free Model.dll
15:28:37 : _DetachDLL Call
15:28:37 : _DetachDLL Call End
15:28:37 : FreeLibrary Call
15:28:39 : FreeLibrary Call End
15:28:40 : wParam : 20, lParam = 0
15:28:40 : MODEL DLL Event : (20, 0)
15:28:40 : Model Dll Msg Not Found(20, 0)
15:28:40 : Page_Error ?κ??Դϴ?
15:28:40 : ????? Retry ?κ??Դϴ?
15:29:01 : Call Retry Thread
15:29:01 : Verifying phone connection...
15:29:01 : dwWaitResetTime(40000 ms)
15:29:05 : _IsConnectedPhone Call
15:29:12 : _IsConnectedPhone(2)
15:29:12 : 0 - NotConnected.
15:29:12 : 1 - Normal connect success
15:29:12 : 2 - Emergency connect success
15:29:12 : Phone Mode(2)
15:29:12 : *****WorkModelDLL Start*****
15:29:13 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
15:29:13 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
15:29:13 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
15:29:13 : m_nPhoneMode(2)
15:29:13 : Phone mode 1 = Normal
15:29:13 : Phone mode 2 = Emergency
15:29:13 : Phone mode 4 = CSE
15:29:13 : _DetachDLL Call
15:29:13 : _DetachDLL Call End
15:29:13 : Call fn_StartUpgrade
15:29:13 : ### Start Upgrade - CDMA ###
15:29:13 : ********* CDMA Model.dll input Parameter *************
15:29:13 : MODEL_EVENT : 32769
15:29:13 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
15:29:13 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
15:29:13 : BootWaitTime : 74250
15:29:13 : UsbHighSpeed : FALSE
15:29:13 : PhoneMode : 2
15:29:13 : NewPhoneBinVersion : LS670ZV9_20
15:29:13 : ClearSI : FALSE
15:29:13 : AuthMark : 5774
15:29:13 : ********* CDMA Model.dll input Parameter End*************
15:29:14 : wParam : 20, lParam = 570
15:29:14 : MODEL DLL Event : (20, 570)
15:29:14 : Model Dll Msg Not Found(20, 570)
15:29:24 : wParam : 6, lParam = 0
15:29:24 : MODEL DLL Event : (6, 0)
15:29:24 : wParam : 100, lParam = 84
15:29:24 : MODEL DLL Event : (100, 84)
15:29:24 : CleanModelDll() : Free Model.dll
15:29:24 : _DetachDLL Call
15:29:24 : _DetachDLL Call End
15:29:24 : FreeLibrary Call
15:29:26 : FreeLibrary Call End
15:29:27 : wParam : 20, lParam = 0
15:29:27 : MODEL DLL Event : (20, 0)
15:29:28 : Model Dll Msg Not Found(20, 0)
15:29:28 : Page_Error ?κ??Դϴ?
15:29:28 : ????? Retry ?κ??Դϴ?
Dsignluckmezc
