Results 1 to 6 of 6
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default Help phone wont usb to computer
    im running cm7.2 kravens and my phone wont hook up to computer it just reboots help please
  2. Thread Author  Thread Author    #2
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default Re: Help phone wont usb to computer
    Quote Originally Posted by epidenimus View Post
    Thanks for the details, log files, and clear statement of the problem. I try to help, but sometimes, I feel like I should just hire to interpret.
    i called up a friend and he told me how to fix it no biggie but thx anyway
  3. #3
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Wonderful! Could you describe your problem and the solution in detail so that it may help others? If not, perhaps consider deleting this thread.
    Thank you.
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    my problem was that my phone wouldnt go into usb storage then i freaked out but i called my friend and he said do a factory reset
  5. #5
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Again, I implore you to just delete this thread, as there is no useful information in it. Further, loosely suggesting a "factory reset" to resolve a USB connection error (usually related to Windoze driver issues) can be problematic for both stock and rooted users.
    Thank you.
  6. #6
    blackops1125's Avatar
    Advisor
    Posts
    Default
    Thank you.
    He can not delete this thread now since you responded to it, if I am not mistaken. Only a moderator can do that now.
    sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
    Always happy to help, hit that thanks button if I did
    Current Device(s): Motorola Droid Razr
    Previous Device(s): LG Optimus S
    Always happy to help out, Just remember to hit that thanks button!
