I use appbrain but was wondering do i need to still save my apps to an SD card?? Or is that just redundant? And then next question is there a way to save my preferences to each app? Thanks for the help
Use an SD card. Better safe then sorry. AppBrain is cookie cutter compared to other sites out there anyways.
What site would you recommend? Most of the one's I've seen have so much advertising garbage in the middle of the page that it's difficult to read, much less find the install links.
I need one that lets me manage my apps, so that I can tag them and install later (which App brain does very well with it's category function).
As for SD card vs site.. my opinion is it's redundant, but then again if an app is removed from the market, your APK would still be there...If there was a way to quickly copy all the apks at once that I use, i'd probably download to my PC rather than the card, right now I've left them in the Appbrain cloud.
Wait, you are backing up apps with an SD card?
I thought that if you got a new phone, you could just sign in and everything is there.
That's what everyone makes it seem when they praise this feature about Android.
as far as backing up apps, use titanium backup if youre rooted, astro file viewer if not
will titanium backup retain your settings for each app?
