Long story short, my Moto X went through the wash and got totally waterlogged. I proceeded to open it up, remove the battery, clean everything with IPA and let it dry for a few days. Now everything is working fine expect for some strange battery issues.
For one, my battery life is absolutely terrible now - I'm talking 4-5 hours at most. I bought a 3rd party battery (Onite) to try, but it was even worse. So now I'm using my original Motorola battery, which isn't even a year old - but may have been damaged by the water.
Another issue is that the charging icon (lightning bolt) is permanently showing, even when the phone is not charging. I think this might be a software issue. Finally, when the battery completely drains it is very difficult to give it power. I leave it plugged in and it remains at 0%...Only after plugging/unplugging a bunch of times and then leaving it plugged in for about an hour will it finally get enough juice to start charging.
What do you think is the problem here? Obviously I can always buy a brand new Motorola battery and try that, but I want to make sure that that is the real problem before I dish out $80 on a battery. If it is a problem with the port or some other connection then I would rather just get a new phone. Any help is appreciated.
