Best Widget that show time, weather and battery power
bigmac429
24
What are the best widgets on the Play Store that show time, weather and battery power? I'm coming from droids with the droid commander center widget. Was hoping for something similar to that.
TqSu
8
I use weather & click widget. Very clean look. Shows time, date, weather, and battery. Tapping on date opens calendar.
Rockler
24
New Command center 2.1.0 Droid Turbo 2 Widget was posted on XDA for both rooted and unrooted .
TqSu
8
How has the app been on battery life for the time you have been using it? I usually just use Google Now for my weather bc I'm worried about adding a weather widget and having it drain my battery. Thanks.
I never noticed any battery drain. You can set the frequency of weather updates.
DerkWehler
6
Try Transparent Weather Clock, I've been using it for years. It's great!
Been using Transparent Weather and Clock for a while. But just recently, it stopped showing my battery level. I have deleted and re-created it, and the template shows it should have battery level on it, but when applied, it doesn't anymore. I don't know what changed. Any ideas?
sbs8331
52
The battery level was removed from the widget. The developer says that it is due to latest Android restrictions, though others (e.g. Chronus) still have it.
Non
