guys..
So another issue that i would love help on is WiF and when it connects
I have WiFi at home and in the office. However once I leave any of these locations, I notice that WiFi tries to connect to other networks ..as its suppose to ..but if I am just out if range or not authorized... It won't work...but While uts trying ...it also has my mobile data disabled.. And I have no functioning connection. I have to stop what I an doing and disable WiFi... Then remember to reenable when I get back.
I have played with the setting for weak connections and that does not help
I have tried a couple of the task application's ..Llama etc and they butchered my battery life...to do what I needed with precise locations you need GPS on. Using the tower locations did not help
Am I asking too much? Ideally if the moto assis should do it...when it detects you driving... Shut off WiFi... But I cannot see how to. There used to be an application in mybikd droid that did this perfectly... Cannot remember the name now but I know it no longer works on this version on droid
Any thoughts ..thanks
