Jeremy8000
Thanks for your response. Money is not a particular concern- I'm not a millionaire or anything, but I can afford to pay for the flagships. I agree, based on my research, that the updates are overrated. But stock Android, from what I hear, is preferable to the skins from the flagships. Is that not true? I had been led to believe that the Nexus 6 (likely) would be the hardware equivalent of the flagships without the bloat and skins, which is why I had earmarked it for my next phone. You know, if it actually will be released in 2014.
Pros for the next Nexus, presuming it follows its historical trend:
- It will be as good as anything out there in terms of raw power, and nothing will run Android OS smoother;
- The screen will be at least 1080P, and imho you won't notice any lack of detail, nor recognize it as being visibly deficient vs a QHD screen unless you scrutinize them closely side by side;
- It may not offer premium build components, but it will be well built and highly functional; and
- It's not that Nexus will get faster updates, but rather, and more importantly, that it will continue to receive updates to subsequent versions for some time (the Nexus 4 is expected to receive L when it releases, despite being two years old). You can rest comfortably that with any other flagship you might currently buy you will receive Android L in time, but unless you're willing to root (which may void your warranty) you may not see subsequent updates for as long as you can anticipate directly on the Nexus devices -- and that can make a big difference down the line (again, if you don't root, and if you expect to keep the phone for more than a year or two).
- In terms of value, it will by far be the "biggest bang for the buck."
Here's a few assorted generic pros for other flagships in comparison:
- They may offer additional software suites (though often only replicating the same function already available on the Nexus (or readily available on Google Play);
- You will have greater option as to display size and resolution (if, for example, N6 comes out with QHD, some might prefer regular HD for the battery efficiency if they don't perceive the display difference);
- You'll have the option of selecting a phone that has whatever level of opulent feel you like;
- A variety of features not likely to be integrated on Nexus are available elsewhere (i.e. IR blaster, fingerprint scanner, waterproof, and most notably micro SD, etc);
- Premium camera. While the Nexus cameras have gotten dramatically better (the N5 is actually quite good), Google hasn't tried to offer the 'best' available; and
- Many are available now.
There is no right answer for everyone - it's what the priorities are for you.
