Well that fixed it!
Now the question is, How and why did google mess it up and how is it, in 3 updates to the google app in the last week, they were they unable to fix it. Assuming they were even trying to.
I've had talkback and other similar unwanted / unneeded google apps disabled forever and none of them ever effected this issue or others.
It's time to hold google responsible for their constant mess ups, half baked ideas and other stupidity.
Sure, android and most of google is "Free". But they are making Mountains of Money off us beta tester / Guinea pigs. So "Free" is a relative term at best.
Having suffered through every "yearly" version of android since the droid eris and just as many devices, I've had enough of their games. Every App, Every OS, Every Device one major issue after the next. They need to stop trying to reinvent the wheel and just maintain and tweek what works. Any Drastic "Improvements / Upgrades" should be tested for months and then give the user the simple option to revert back to what worked or was better. Kind of like what they tried with the nugat developer betas, then didnt implement by releasing 7.0 with its Bluetooth and other battery draining issues .
Example; - Large White text on Dark Backgrounds vs the Horrendous often impossible to read Tiny Light gray / light Pastel colored text on Bright white backgrounds that has infected all things android since the self heralded, battery draining "Material" design took over. Personally, I cant wait for the New White font on white backgrounds that's sure to come one day!
Why do they have NO customer support? why do we have to search the dark corners of the internet to fix these rampant issues that appear almost daily?
It's 2016 and they still run the company like its some garage based start-up
Sure, they have their so called "Support forms" where, if you are lucky enough to accurately describe your issue you may find a link to them by googling it.
But once there, you will soon discover they are just customer ranting forms. Nobody who actually works at google monitors them. In Nearly every thread there's the almost identical, verbatim post by Jill or Joe Jag off, Who is nothing more than a glorified Hall monitor, dying to work for google and thinks his or her "helpful" posts will help. Maybe it's a requirement to get a job at the only company in the world with virtually No customer service on its largest and most lucrative products. Either way, they are never helpful.
Their posts all go something like; Welcome to the form.... My name is... Send a screen cap.... I will Pass it on to the "Mythical and Elusive" team.... etc. They almost never understand the problem being described and if they ad a follow up post it almost always mentions, rebooting, delete any new app and or do a factory reset. That's their answer for everything.
