this is what i do after writeing the .nvs file to zvd to get data back
To Restore Data on LS670 Firmware:
1: Install anycut.apk
2: Run anycut and "create shortcut"-"Activity"-"LG HIDDEN DATA" and hit ok
3: Return to desktop and open the shortcut
4: go into CDG2 Data Settings and change PPP CARRIER from Sprint to Undetermined
5: Hit back and the phone will reboot
6: Open Qpst service programing and hit Load from file
7: Select the .qcn file you saved durring prep
8: Select write to phone and enter your spc
9: The phone will reboot
10: Open LGNPST and Select "Phone Setting" Enter your Spc hit ok then Read
11: Close lgnpst and open DFS and enter your Spc and click SPC
12: Click the Programing Tab then the Mobile IP TAB and click Read
13: On the first Profile Uncheck the boxes next to Enter value in HEX for both AAA Shared Secret and HA Shared Secret
14: Clear anything there and click write current profile settings
15: go to profile 3 and Uncheck the Enter Value in HEX box for AAA Shared Secret and Copy the value
16: Go To profile 2 and Paste that value into AAA Shared Secret box and Enter Vmug33k for HA shared Secret
17: Hit Write current profile settings and switch to the data tab next to mobile ip and hit read
18: under HDR AN and HDR AN Long you'll see
YOURMEID@mdata.vmobl.com with PWD boxes under them
19: Paste your AAA Key that you copied earlier into both pwd boxes and hit write
Reboot Phone and you will have Data
