Huawei G300+ hot and draining battery
Treebone
My G300+ has (in the last couple of days) started running very hot (50c) and is draining the battery extremely fast (about an hour to drain from 100%).
I have had the phone for almost a year and until not there has been no problems.
I have removed all my apps and done a factory reboot and it is still hot and draining.
I have removed the SD card and it is still hot and draining.
I have changed SIM card and it is still hot and draining.
I have put it in flight mode and it cools down and battery is ok ... but flight mode is essentially useless.
I put a battery monitor app on to see what is using the battery and it indicates that "Radio Signal" is what is using the power - signal strength is always high and I am in a "5-bar" service area.
I guess this is the root of the problem, but I'm clueless as to how to fix the problem.
Should get a new battery?
Should I get a new phone?
Any help would be appreciated.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
116
63
Welcome to the forums.
With everything you have described, it sounds like there is a problem with either the physical radios or the software dealing with them. If it were me, I might start looking at a new phone.
max mays
